Salta al contenuto principale
WRS315SDHW Temperature Control Board Replacement
Cosa ti serve
  1. WRS315SDHW Temperature Control Board Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Temperature Control Board Replacement, Open the doors: passo 2, immagine 1 di 3 WRS315SDHW Temperature Control Board Replacement, Open the doors: passo 2, immagine 2 di 3 WRS315SDHW Temperature Control Board Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Temperature Control Board Replacement, Unfasten the temperature control board assembly: passo 3, immagine 1 di 2 WRS315SDHW Temperature Control Board Replacement, Unfasten the temperature control board assembly: passo 3, immagine 2 di 2
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly.
  4. WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: passo 4, immagine 1 di 3 WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: passo 4, immagine 2 di 3 WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: passo 4, immagine 3 di 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: passo 5, immagine 1 di 3 WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: passo 5, immagine 2 di 3 WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: passo 5, immagine 3 di 3
    • Disconnect the two spade connectors attached to the temperature control board assembly.
  6. WRS315SDHW Temperature Control Board Replacement, Remove the assembly: passo 6, immagine 1 di 1
    • Remove the temperature control board assembly.
  7. WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: passo 7, immagine 1 di 3 WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: passo 7, immagine 2 di 3 WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: passo 7, immagine 3 di 3
    • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
    • Use another flathead screwdriver to pry up the board from its housing.
  8. WRS315SDHW Temperature Control Board Replacement, Remove the temperature control board: passo 8, immagine 1 di 1
    • Pull the temperature control board straight out of its housing to remove it.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.945 Reputazione
89 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 214
