Salta al contenuto principale
WRS315SDHW Refrigerator Thermistor Replacement
Cosa ti serve
  1. WRS315SDHW Refrigerator Thermistor Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: passo 2, immagine 1 di 3 WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: passo 2, immagine 2 di 3 WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: passo 3, immagine 1 di 2 WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: passo 3, immagine 2 di 2
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly (shown with the assembly removed).
  4. WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: passo 4, immagine 1 di 3 WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: passo 4, immagine 2 di 3 WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: passo 4, immagine 3 di 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: passo 5, immagine 1 di 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: passo 5, immagine 2 di 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: passo 5, immagine 3 di 3
    • Disconnect the two harness connectors attached to the temperature control board assembly.
  6. WRS315SDHW Refrigerator Thermistor Replacement, Remove the assembly: passo 6, immagine 1 di 1
    • Remove the temperature control board assembly.
  7. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: passo 7, immagine 1 di 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: passo 7, immagine 2 di 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: passo 7, immagine 3 di 3
    • Pinch and pull the connector attached to the thermistor to disconnect it.
  8. WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: passo 8, immagine 1 di 2 WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: passo 8, immagine 2 di 2
    • Use a flathead screwdriver, or a similar tool, to pry up the thermistor from its slot in the chassis.
    • Remove the thermistor.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.927 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
576 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 152
