Introduzione
Use this guide to replace the icemaker assembly in your Whirlpool WRS315SDHW Refrigerator.
The icemaker assembly is a combination of parts that creates ice. If your refrigerator isn't producing ice, or is producing too much ice, then your icemaker might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Cosa ti serve
Pull the icemaker tray completely out of its slot in the chassis.
Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
Two 23.9 mm-long screws
One 16.7 mm-long screw
Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
Let the icemaker assembly hang to access its connector.
Disconnect the spade connector attached to the icemaker assembly.
Repair didn’t go as planned? Ask our Answers community for help.
