Salta al contenuto principale
WRS315SDHW Freezer Door Replacement
Cosa ti serve
  1. WRS315SDHW Freezer Door Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Freezer Door Replacement, Open the doors: passo 2, immagine 1 di 3 WRS315SDHW Freezer Door Replacement, Open the doors: passo 2, immagine 2 di 3 WRS315SDHW Freezer Door Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Freezer Door Replacement, Unfasten the front panel: passo 3, immagine 1 di 3 WRS315SDHW Freezer Door Replacement, Unfasten the front panel: passo 3, immagine 2 di 3 WRS315SDHW Freezer Door Replacement, Unfasten the front panel: passo 3, immagine 3 di 3
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  4. WRS315SDHW Freezer Door Replacement, Remove the front panel: passo 4, immagine 1 di 3 WRS315SDHW Freezer Door Replacement, Remove the front panel: passo 4, immagine 2 di 3 WRS315SDHW Freezer Door Replacement, Remove the front panel: passo 4, immagine 3 di 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. WRS315SDHW Freezer Door Replacement, Unfasten the door connections: passo 5, immagine 1 di 2 WRS315SDHW Freezer Door Replacement, Unfasten the door connections: passo 5, immagine 2 di 2
    • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the freezer door wiring harness.
    • Use a 1/4 inch socket wrench to remove the 16.2 mm-long screw securing the freezer door water hose.
  6. WRS315SDHW Freezer Door Replacement, Reposition the wiring harness: passo 6, immagine 1 di 2 WRS315SDHW Freezer Door Replacement, Reposition the wiring harness: passo 6, immagine 2 di 2
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: passo 7, immagine 1 di 3 WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: passo 7, immagine 2 di 3 WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: passo 7, immagine 3 di 3
    • Disconnect the two connectors attached to the door wiring harness.
  8. WRS315SDHW Freezer Door Replacement: passo 8, immagine 1 di 1
    • Place a clean cloth under the water hose before continuing.
  9. WRS315SDHW Freezer Door Replacement: passo 9, immagine 1 di 2 WRS315SDHW Freezer Door Replacement: passo 9, immagine 2 di 2
    • Pull the plastic clip off the freezer door water hose.
  10. WRS315SDHW Freezer Door Replacement, Disconnect the water hose: passo 10, immagine 1 di 3 WRS315SDHW Freezer Door Replacement, Disconnect the water hose: passo 10, immagine 2 di 3 WRS315SDHW Freezer Door Replacement, Disconnect the water hose: passo 10, immagine 3 di 3
    • Use one hand to compress the blue plastic ring into the green section of the hose.
    • Use the other hand to pull the white water tube out of its slot.
  11. WRS315SDHW Freezer Door Replacement, Unfasten the freezer door: passo 11, immagine 1 di 2 WRS315SDHW Freezer Door Replacement, Unfasten the freezer door: passo 11, immagine 2 di 2
    • Hold the door while performing the next two steps to avoid the door from accidentally falling.
    • Use a 3/16 inch Allen wrench to remove the two 19.3 mm-long screws securing the freezer door.
    • The Torx screws are for alignment and don't need to be removed.
  12. WRS315SDHW Freezer Door Replacement, Remove the door hinge: passo 12, immagine 1 di 3 WRS315SDHW Freezer Door Replacement, Remove the door hinge: passo 12, immagine 2 di 3 WRS315SDHW Freezer Door Replacement, Remove the door hinge: passo 12, immagine 3 di 3
    • Pull the door hinge straight up to separate its alignment pins from the chassis.
    • Remove the door hinge.
  13. WRS315SDHW Freezer Door Replacement, Reposition the cables: passo 13, immagine 1 di 3 WRS315SDHW Freezer Door Replacement, Reposition the cables: passo 13, immagine 2 di 3 WRS315SDHW Freezer Door Replacement, Reposition the cables: passo 13, immagine 3 di 3
    • Pull the freezer door straight up to disconnect it from the chassis.
    • Thread the cables through their slot in the chassis.
    • You may need to thread them individually.
  14. WRS315SDHW Freezer Door Replacement, Remove the door: passo 14, immagine 1 di 2 WRS315SDHW Freezer Door Replacement, Remove the door: passo 14, immagine 2 di 2
    • You're now left with the freezer door.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.945 Reputazione
89 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 195
