Salta al contenuto principale
WRS315SDHW Evaporator Fan Replacement
Cosa ti serve
  1. WRS315SDHW Evaporator Fan Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Evaporator Fan Replacement, Open the doors: passo 2, immagine 1 di 3 WRS315SDHW Evaporator Fan Replacement, Open the doors: passo 2, immagine 2 di 3 WRS315SDHW Evaporator Fan Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Evaporator Fan Replacement, Remove the drawers: passo 3, immagine 1 di 2 WRS315SDHW Evaporator Fan Replacement, Remove the drawers: passo 3, immagine 2 di 2
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Evaporator Fan Replacement: passo 4, immagine 1 di 2 WRS315SDHW Evaporator Fan Replacement: passo 4, immagine 2 di 2
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: passo 5, immagine 1 di 3 WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: passo 5, immagine 2 di 3 WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: passo 5, immagine 3 di 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: passo 6, immagine 1 di 3 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: passo 6, immagine 2 di 3 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: passo 6, immagine 3 di 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Evaporator Fan Replacement, Disconnect the evaporator fan: passo 7, immagine 1 di 2 WRS315SDHW Evaporator Fan Replacement, Disconnect the evaporator fan: passo 7, immagine 2 di 2
    • Use needle nose pliers, or your fingers, to disconnect the grounding wire attached to the evaporator fan.
  8. WRS315SDHW Evaporator Fan Replacement: passo 8, immagine 1 di 3 WRS315SDHW Evaporator Fan Replacement: passo 8, immagine 2 di 3 WRS315SDHW Evaporator Fan Replacement: passo 8, immagine 3 di 3
    • Disconnect the connector attached to the evaporator fan.
  9. WRS315SDHW Evaporator Fan Replacement, Unfasten the evaporator fan: passo 9, immagine 1 di 1
    • Use a 1/4 inch socket wrench to remove the two 13 mm-long screws securing the evaporator fan.
  10. WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: passo 10, immagine 1 di 3 WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: passo 10, immagine 2 di 3 WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: passo 10, immagine 3 di 3
    • Slide the foam buffer downward to release it from its lip in the chassis.
    • Remove the foam buffer.
    • Repeat this procedure for the second foam buffer.
  11. WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: passo 11, immagine 1 di 3 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: passo 11, immagine 2 di 3 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: passo 11, immagine 3 di 3
    • Pull the evaporator fan housing up and outward from the chassis to remove it.
  12. WRS315SDHW Evaporator Fan Replacement, Remove the fan: passo 12, immagine 1 di 2 WRS315SDHW Evaporator Fan Replacement, Remove the fan: passo 12, immagine 2 di 2
    • Pull the evaporator fan straight off its motor to remove it.
    • This may require some significant force.
  13. WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: passo 13, immagine 1 di 3 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: passo 13, immagine 2 di 3 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: passo 13, immagine 3 di 3
    • Use your fingers to pry up and release the motor bracket clips from the housing.
  14. WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: passo 14, immagine 1 di 2 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: passo 14, immagine 2 di 2
    • Remove the motor bracket.
  15. WRS315SDHW Evaporator Fan Replacement, Remove the motor: passo 15, immagine 1 di 3 WRS315SDHW Evaporator Fan Replacement, Remove the motor: passo 15, immagine 2 di 3 WRS315SDHW Evaporator Fan Replacement, Remove the motor: passo 15, immagine 3 di 3
    • Pull the motor straight out of its housing to remove it.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.945 Reputazione
89 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 308
