Salta al contenuto principale
WRS315SDHW Dispenser Assembly Replacement
Cosa ti serve
  1. WRS315SDHW Dispenser Assembly Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Dispenser Assembly Replacement, Unfasten the dispenser panels: passo 2, immagine 1 di 2 WRS315SDHW Dispenser Assembly Replacement, Unfasten the dispenser panels: passo 2, immagine 2 di 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: passo 3, immagine 1 di 3 WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: passo 3, immagine 2 di 3 WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: passo 3, immagine 3 di 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Dispenser Assembly Replacement, Unfasten the control board: passo 4, immagine 1 di 1
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Dispenser Assembly Replacement: passo 5, immagine 1 di 3 WRS315SDHW Dispenser Assembly Replacement: passo 5, immagine 2 di 3 WRS315SDHW Dispenser Assembly Replacement: passo 5, immagine 3 di 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: passo 6, immagine 1 di 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: passo 6, immagine 2 di 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: passo 6, immagine 3 di 3
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Dispenser Assembly Replacement: passo 7, immagine 1 di 2 WRS315SDHW Dispenser Assembly Replacement: passo 7, immagine 2 di 2
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Dispenser Assembly Replacement, Remove the control board: passo 8, immagine 1 di 1
    • Remove the control board.
  9. WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: passo 9, immagine 1 di 3 WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: passo 9, immagine 2 di 3 WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: passo 9, immagine 3 di 3
    • Use a flathead screwdriver, or a similar tool, to pry up the plastic clip securing the water hose.
    • Remove the plastic clip.
  10. WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: passo 10, immagine 1 di 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: passo 10, immagine 2 di 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: passo 10, immagine 3 di 3
    • Use a flathead screwdriver, or a similar tool, to pry up the water hose enough to grip it with your fingers.
    • Pull the water hose straight up to disconnect it.
  11. WRS315SDHW Dispenser Assembly Replacement, Reposition the cables: passo 11, immagine 1 di 2 WRS315SDHW Dispenser Assembly Replacement, Reposition the cables: passo 11, immagine 2 di 2
    • Reposition the cables so they lay in front of the top plastic clip.
  12. WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: passo 12, immagine 1 di 3 WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: passo 12, immagine 2 di 3 WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: passo 12, immagine 3 di 3
    • There are two plastic clips that secure the dispenser assembly in the chassis.
    • Use a flathead screwdriver, or a similar tool, to press the plastic clip toward the dispenser assembly.
    • Repeat for the other plastic clip to completely separate the dispenser assembly from the chassis.
  13. WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: passo 13, immagine 1 di 3 WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: passo 13, immagine 2 di 3 WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: passo 13, immagine 3 di 3
    • Pull the dispenser assembly away from the chassis enough to access its connectors.
  14. WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: passo 14, immagine 1 di 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: passo 14, immagine 2 di 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: passo 14, immagine 3 di 3
    • While performing this step, support the dispenser assembly so it doesn't fall.
    • Disconnect the connector attached to the dispenser assembly.
  15. WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser assembly: passo 15, immagine 1 di 1
    • Remove the dispenser assembly.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.927 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
558 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 145
