Salta al contenuto principale
WRS315SDHW Defrost Heater Replacement
Cosa ti serve
  1. WRS315SDHW Defrost Heater Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Defrost Heater Replacement, Open the doors: passo 2, immagine 1 di 3 WRS315SDHW Defrost Heater Replacement, Open the doors: passo 2, immagine 2 di 3 WRS315SDHW Defrost Heater Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Defrost Heater Replacement, Remove the drawers: passo 3, immagine 1 di 2 WRS315SDHW Defrost Heater Replacement, Remove the drawers: passo 3, immagine 2 di 2
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Defrost Heater Replacement: passo 4, immagine 1 di 2 WRS315SDHW Defrost Heater Replacement: passo 4, immagine 2 di 2
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: passo 5, immagine 1 di 3 WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: passo 5, immagine 2 di 3 WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: passo 5, immagine 3 di 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: passo 6, immagine 1 di 3 WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: passo 6, immagine 2 di 3 WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: passo 6, immagine 3 di 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: passo 7, immagine 1 di 3 WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: passo 7, immagine 2 di 3 WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: passo 7, immagine 3 di 3
    • Disconnect the two spade connectors attached to the defrost heater.
  8. WRS315SDHW Defrost Heater Replacement, Reposition the cable: passo 8, immagine 1 di 3 WRS315SDHW Defrost Heater Replacement, Reposition the cable: passo 8, immagine 2 di 3 WRS315SDHW Defrost Heater Replacement, Reposition the cable: passo 8, immagine 3 di 3
    • Pull the defrost heater cable out from behind the evaporator.
  9. WRS315SDHW Defrost Heater Replacement, Unfasten the defrost heater bracket: passo 9, immagine 1 di 1
    • Use a 1/4 inch socket wrench to remove the 16.5 mm-long screw securing the defrost heater bracket.
  10. WRS315SDHW Defrost Heater Replacement, Release the defrost heater bracket: passo 10, immagine 1 di 2 WRS315SDHW Defrost Heater Replacement, Release the defrost heater bracket: passo 10, immagine 2 di 2
    • Pull the defrost heater bracket up to release it from its slot in the chassis.
  11. WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: passo 11, immagine 1 di 3 WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: passo 11, immagine 2 di 3 WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: passo 11, immagine 3 di 3
    • Slide the defrost heater from under the evaporator.
    • You may need to pull one end at a time until it's completely removed.
  12. WRS315SDHW Defrost Heater Replacement, Only the defrost heater remains: passo 12, immagine 1 di 1
    • You're now left with the defrost heater.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.945 Reputazione
89 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 393
