Salta al contenuto principale
WRS315SDHW Control Board Replacement
Cosa ti serve
  1. WRS315SDHW Control Board Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: passo 2, immagine 1 di 2 WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: passo 2, immagine 2 di 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Control Board Replacement, Remove the dispenser panels: passo 3, immagine 1 di 3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: passo 3, immagine 2 di 3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: passo 3, immagine 3 di 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Control Board Replacement, Unfasten the control board: passo 4, immagine 1 di 1
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Control Board Replacement: passo 5, immagine 1 di 3 WRS315SDHW Control Board Replacement: passo 5, immagine 2 di 3 WRS315SDHW Control Board Replacement: passo 5, immagine 3 di 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Control Board Replacement, Disconnect the control board: passo 6, immagine 1 di 3 WRS315SDHW Control Board Replacement, Disconnect the control board: passo 6, immagine 2 di 3 WRS315SDHW Control Board Replacement, Disconnect the control board: passo 6, immagine 3 di 3
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Control Board Replacement: passo 7, immagine 1 di 2 WRS315SDHW Control Board Replacement: passo 7, immagine 2 di 2
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Control Board Replacement, Remove the control board: passo 8, immagine 1 di 1
    • Remove the control board.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.945 Reputazione
89 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 634
