Salta al contenuto principale
WRS315SDHW Auger Motor Replacement
Cosa ti serve
  1. WRS315SDHW Auger Motor Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Auger Motor Replacement, Open the doors: passo 2, immagine 1 di 3 WRS315SDHW Auger Motor Replacement, Open the doors: passo 2, immagine 2 di 3 WRS315SDHW Auger Motor Replacement, Open the doors: passo 2, immagine 3 di 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Auger Motor Replacement, Remove the icemaker tray: passo 3, immagine 1 di 2 WRS315SDHW Auger Motor Replacement, Remove the icemaker tray: passo 3, immagine 2 di 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Auger Motor Replacement, Unfasten the icemaker assembly: passo 4, immagine 1 di 2 WRS315SDHW Auger Motor Replacement, Unfasten the icemaker assembly: passo 4, immagine 2 di 2
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: passo 5, immagine 1 di 3 WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: passo 5, immagine 2 di 3 WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: passo 5, immagine 3 di 3
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: passo 6, immagine 1 di 3 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: passo 6, immagine 2 di 3 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: passo 6, immagine 3 di 3
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Auger Motor Replacement, Remove the icemaker assembly: passo 7, immagine 1 di 1
    • Remove the icemaker assembly.
  8. WRS315SDHW Auger Motor Replacement, Unfasten the icemaker auger assembly: passo 8, immagine 1 di 1
    • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
    • Two 24.1 mm-long screws
    • Two 16.5 mm-long screws
  9. WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: passo 9, immagine 1 di 3 WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: passo 9, immagine 2 di 3 WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: passo 9, immagine 3 di 3
    • Pull the icemaker auger assembly off of its slot in the chassis.
    • Let the assembly hang to access its connector.
  10. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: passo 10, immagine 1 di 3 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: passo 10, immagine 2 di 3 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: passo 10, immagine 3 di 3
    • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
    • Use your hands to disconnect the assembly connector.
  11. WRS315SDHW Auger Motor Replacement, Remove the icemaker auger assembly: passo 11, immagine 1 di 1
    • Remove the icemaker auger assembly.
  12. WRS315SDHW Auger Motor Replacement, Remove the auger fin: passo 12, immagine 1 di 3 WRS315SDHW Auger Motor Replacement, Remove the auger fin: passo 12, immagine 2 di 3 WRS315SDHW Auger Motor Replacement, Remove the auger fin: passo 12, immagine 3 di 3
    • Twist the auger fin clockwise until it separates from the assembly.
    • Remove the auger fin.
  13. WRS315SDHW Auger Motor Replacement, Unfasten the grounding wire: passo 13, immagine 1 di 1
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 11.6 mm-long screw securing the grounding wire.
  14. WRS315SDHW Auger Motor Replacement, Unfasten the auger motor: passo 14, immagine 1 di 1
    • Use a 1/4 inch socket wrench to remove the three 16.7 mm-long screws securing the auger motor.
  15. WRS315SDHW Auger Motor Replacement, Disconnect the auger motor: passo 15, immagine 1 di 2 WRS315SDHW Auger Motor Replacement, Disconnect the auger motor: passo 15, immagine 2 di 2
    • Use needle nose pliers, or your hands, to disconnect the grounding wire from the auger motor.
  16. WRS315SDHW Auger Motor Replacement: passo 16, immagine 1 di 3 WRS315SDHW Auger Motor Replacement: passo 16, immagine 2 di 3 WRS315SDHW Auger Motor Replacement: passo 16, immagine 3 di 3
    • Disconnect the two spade connectors attached to the auger motor.
  17. WRS315SDHW Auger Motor Replacement, Only the auger motor remains: passo 17, immagine 1 di 1
    • You're now left with the auger motor.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.927 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
576 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 118
