Salta al contenuto principale
Vtech Kidizoom Smart Watch DX Buttons Replacement
Cosa ti serve
  1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: passo 1, immagine 1 di 1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 2, immagine 1 di 1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 3, immagine 1 di 1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 4, immagine 1 di 2 Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 4, immagine 2 di 2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: passo 5, immagine 1 di 2 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: passo 5, immagine 2 di 2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 6, immagine 1 di 1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 7, immagine 1 di 1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 8, immagine 1 di 1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 9, immagine 1 di 1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: passo 10, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use the the tweezers to pull off the blue rubber cover behind the button.
    • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
  11. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 11, immagine 1 di 1
    • Use tweezers to separate the backside tab from the front side of the button.
  12. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 12, immagine 1 di 1
    • Push the other half of the button out of the casing.
    • Repeat steps 11 and 12 for all buttons.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 10-6, Remmell Spring 2016 Membro di USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Membri
12 Guide realizzate
1Commento della guida
Where can you buy the replacement cover?
Katrina Nullatamby - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 33
Tutti i Tempi: 6,136
