Salta al contenuto principale
Vizio SmartCast Crave 360 Battery Replacement
Cosa ti serve
  1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: passo 1, immagine 1 di 2 Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Battery Replacement: passo 3, immagine 1 di 2 Vizio SmartCast Crave 360 Battery Replacement: passo 3, immagine 2 di 2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Battery Replacement, Bass: passo 4, immagine 1 di 2 Vizio SmartCast Crave 360 Battery Replacement, Bass: passo 4, immagine 2 di 2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Battery Replacement: passo 5, immagine 1 di 3 Vizio SmartCast Crave 360 Battery Replacement: passo 5, immagine 2 di 3 Vizio SmartCast Crave 360 Battery Replacement: passo 5, immagine 3 di 3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
  6. Vizio SmartCast Crave 360 Battery Replacement, Battery: passo 6, immagine 1 di 2 Vizio SmartCast Crave 360 Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Flip the speaker to access the top.
    • Remove the eight 10 mm screws from the plastic disc inside the grey speaker cage using a Phillips #000 screwdriver.
    • Remove the plastic disc from the speaker cage.
  7. Vizio SmartCast Crave 360 Battery Replacement: passo 7, immagine 1 di 1
    • Lift the grey speaker cage to reveal a black plastic cylinder that contains the battery.
  8. Vizio SmartCast Crave 360 Battery Replacement: passo 8, immagine 1 di 2 Vizio SmartCast Crave 360 Battery Replacement: passo 8, immagine 2 di 2
    • Disconnect the wire that connects the motherboard to the battery.
  9. Vizio SmartCast Crave 360 Battery Replacement: passo 9, immagine 1 di 2 Vizio SmartCast Crave 360 Battery Replacement: passo 9, immagine 2 di 2
    • Remove the motherboard and battery from the plastic cylinder.
  10. Vizio SmartCast Crave 360 Battery Replacement: passo 10, immagine 1 di 1
    • Remove the four 5 mm screws from the motherboard using a Phillips #000 screwdriver.
  11. Vizio SmartCast Crave 360 Battery Replacement: passo 11, immagine 1 di 1
    • Remove the motherboard from the battery.
Conclusione
Un commento
Any other way to charge the battery without the charging station or is there a compatible charging station?
Trading Azteca - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 78
Tutti i Tempi: 1,128
