Salta al contenuto principale
Vizio SmartCast Crave 360 Bass Replacement
Cosa ti serve
  1. Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: passo 1, immagine 1 di 2 Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Bass Replacement: passo 2, immagine 1 di 1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Bass Replacement: passo 3, immagine 1 di 2 Vizio SmartCast Crave 360 Bass Replacement: passo 3, immagine 2 di 2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Bass Replacement, Bass: passo 4, immagine 1 di 2 Vizio SmartCast Crave 360 Bass Replacement, Bass: passo 4, immagine 2 di 2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Bass Replacement: passo 5, immagine 1 di 3 Vizio SmartCast Crave 360 Bass Replacement: passo 5, immagine 2 di 3 Vizio SmartCast Crave 360 Bass Replacement: passo 5, immagine 3 di 3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 35
Tutti i Tempi: 665
