Salta al contenuto principale
Vivitar Vivicam T027 Power Button Replacement
Cosa ti serve
  1. Vivitar Vivicam T027 Power Button Replacement, Power Button: passo 1, immagine 1 di 2 Vivitar Vivicam T027 Power Button Replacement, Power Button: passo 1, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
    • You will find one screw on the top, one on the bottom, and one on each side of the camera.
    • Put the screws in a safe place so you can find them and put them back in later.
  2. Vivitar Vivicam T027 Power Button Replacement: passo 2, immagine 1 di 1
    • Remove the sticker on the top of the camera.
    • Use the Phillips #00 screwdriver to remove the screw that was underneath the sticker.
  3. Vivitar Vivicam T027 Power Button Replacement: passo 3, immagine 1 di 2 Vivitar Vivicam T027 Power Button Replacement: passo 3, immagine 2 di 2
    • Separate the front and the back of the camera completely to expose the motherboard.
  4. Vivitar Vivicam T027 Power Button Replacement: passo 4, immagine 1 di 1
    • Locate the power button on the top of the camera.
    • Using tweezers, gently remove the black plastic cover from the power button.
  5. Vivitar Vivicam T027 Power Button Replacement: passo 5, immagine 1 di 2 Vivitar Vivicam T027 Power Button Replacement: passo 5, immagine 2 di 2
    • Using a soldering kit, de-solder the black and red wire from the silver power button.
    • Solder the new power button to the black and red wire.
    • To avoid burns, be careful of the heat from the soldering iron.
    • Reference the soldering guide for assistance!
Conclusione
Dana
Membro da: 03/11/15
110 Reputazione
1 Guida realizzata
Marist, Team 15-13, Laflen Spring 2015 Membro di Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 863
