Salta al contenuto principale
Velocity Micro Cruz T301 Battery Replacement
Cosa ti serve
  1. Velocity Micro Cruz T301 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Insert the plastic iFixit opening tool into the SD port. Orient the iFixit opening tool so that the edge faces the rear panel.
  2. Velocity Micro Cruz T301 Battery Replacement: passo 2, immagine 1 di 1
    • Use the iFixit opening tools to pry open a gap between the tablet and rear panel.
  3. Velocity Micro Cruz T301 Battery Replacement: passo 3, immagine 1 di 2 Velocity Micro Cruz T301 Battery Replacement: passo 3, immagine 2 di 2
    • Move the small tool opener around the rear panel to free the 12 clips.
  4. Velocity Micro Cruz T301 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the four screws in the metal battery housing using the Phillips #0 screwdriver.
  5. Velocity Micro Cruz T301 Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the battery using the spudger.
  6. Velocity Micro Cruz T301 Battery Replacement: passo 6, immagine 1 di 1
    • Lift the battery out of its place with a nylon spudger.
    • This photo shows the use of an incorrect tool. Always use an ESD safe tool, like the nylon spudger, when dealing with delicate components.
Conclusione
USF Tampa, Team 1-6, Cagle Fall 2016 Membro di USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 522
