Salta al contenuto principale
VTech VM3254 Monitor Speaker Replacement
Cosa ti serve
  1. VTech VM3254 Monitor Speaker Replacement, Battery: passo 1, immagine 1 di 2 VTech VM3254 Monitor Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Monitor Speaker Replacement: passo 2, immagine 1 di 3 VTech VM3254 Monitor Speaker Replacement: passo 2, immagine 2 di 3 VTech VM3254 Monitor Speaker Replacement: passo 2, immagine 3 di 3
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Monitor Speaker Replacement: passo 3, immagine 1 di 2 VTech VM3254 Monitor Speaker Replacement: passo 3, immagine 2 di 2
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Monitor Speaker Replacement: passo 4, immagine 1 di 3 VTech VM3254 Monitor Speaker Replacement: passo 4, immagine 2 di 3 VTech VM3254 Monitor Speaker Replacement: passo 4, immagine 3 di 3
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
  5. VTech VM3254 Monitor Speaker Replacement, Monitor Speaker: passo 5, immagine 1 di 2 VTech VM3254 Monitor Speaker Replacement, Monitor Speaker: passo 5, immagine 2 di 2
    • Remove the two 7 mm Phillips #00 screws from the speaker.
    • Carefully remove the speaker and its cords from the motherboard.
    • Handle gently to not break the motherboard or any other parts.
  6. VTech VM3254 Monitor Speaker Replacement: passo 6, immagine 1 di 1
    • Desolder the wire connecting the speaker to the board.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 347
