Salta al contenuto principale
VTech Little Apps Tablet LED Replacement
Cosa ti serve
    1. VTech Little Apps Tablet LED Replacement, Battery: passo 1, immagine 1 di 1
      • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
      Chiedi a FixBot
      Aggiungi Commento
    2. VTech Little Apps Tablet LED Replacement: passo 2, immagine 1 di 1
      • Use a plastic opening tool to pry the batteries out of their holding.
      • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
      Chiedi a FixBot
      Aggiungi Commento
    1. VTech Little Apps Tablet LED Replacement, Back Cover: passo 3, immagine 1 di 2 VTech Little Apps Tablet LED Replacement, Back Cover: passo 3, immagine 2 di 2
      • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
      • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
      Chiedi a FixBot
      Aggiungi Commento
    2. VTech Little Apps Tablet LED Replacement: passo 4, immagine 1 di 2 VTech Little Apps Tablet LED Replacement: passo 4, immagine 2 di 2
      • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
      • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
      Chiedi a FixBot
      Aggiungi Commento
    1. VTech Little Apps Tablet LED Replacement, LED: passo 5, immagine 1 di 1
      • Unscrew the two 7.3 mm screws using a PH0 driver head.
      • Gently lift the beige circuit board and set aside.
      • Be sure to not damage the wires connecting the circuit board to the motherboard, you are only creating space to work in.
      Chiedi a FixBot
      Aggiungi Commento
    2. VTech Little Apps Tablet LED Replacement: passo 6, immagine 1 di 2 VTech Little Apps Tablet LED Replacement: passo 6, immagine 2 di 2
      • Unscrew three 7.3 mm panhead screws with the PH0 driver.
      • Remove the red-brown washer after removing the screws.
      • Remove the black foam insert and set aside.
      Chiedi a FixBot
      Aggiungi Commento
    3. VTech Little Apps Tablet LED Replacement: passo 7, immagine 1 di 1
      • Unscrew the 7.3 mm screw fastening the LED circuit board to the device shell with a PH0 driver head.
      • Be careful when rescrewing circuit boards. Too much pressure or too tight of screws could damage them.
      Chiedi a FixBot
      Aggiungi Commento
    4. VTech Little Apps Tablet LED Replacement: passo 8, immagine 1 di 2 VTech Little Apps Tablet LED Replacement: passo 8, immagine 2 di 2
      • Gently lift both LED circuit board and the white glass light refractor panel away from the device.
      • Separate the LED circuit board and light refractor panel by gently pulling apart. Place the light panel to the side.
      • Skip the next step if you are proceeding with this guide as a part of the Screen Replacement.
      Chiedi a FixBot
      Aggiungi Commento
    5. VTech Little Apps Tablet LED Replacement: passo 9, immagine 1 di 1
      • Carefully desolder the LED leads (labeled "R", "+" and "B" on the circuit board) to disconnect the LED from the circuit board.
      • Replace the LED and solder the new connection to the LED circuit board.
      • Refer to the iFixit Soldering Guide for assistance.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team 2-6, Sullivan Spring 2016 Membro di USF Tampa, Team 2-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G6
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 32
Tutti i Tempi: 928
