Salta al contenuto principale
VTech Learning Tunes Karaoke Volume Switch Replacement
Cosa ti serve
  1. VTech Learning Tunes Karaoke Volume Switch Replacement, Volume Switch: passo 1, immagine 1 di 1
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 2, immagine 1 di 2 VTech Learning Tunes Karaoke Volume Switch Replacement: passo 2, immagine 2 di 2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 3, immagine 1 di 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 4, immagine 1 di 2 VTech Learning Tunes Karaoke Volume Switch Replacement: passo 4, immagine 2 di 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 5, immagine 1 di 2 VTech Learning Tunes Karaoke Volume Switch Replacement: passo 5, immagine 2 di 2
    • Using a Phillips PH1 screwdriver, remove the two 7.9 mm volume switch board screws.
  6. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 6, immagine 1 di 1
    • Once the screws have been removed, carefully move the volume switch board.
  7. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 7, immagine 1 di 1
Conclusione
USF Tampa, Team 7-2, Cheng Spring 2016 Membro di USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 263
