Salta al contenuto principale
VTech Learning Tunes Karaoke Speaker Replacement
Cosa ti serve
  1. VTech Learning Tunes Karaoke Speaker  Replacement, Speaker: passo 1, immagine 1 di 1
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
    Chiedi a FixBot
  2. VTech Learning Tunes Karaoke Speaker  Replacement: passo 2, immagine 1 di 2 VTech Learning Tunes Karaoke Speaker  Replacement: passo 2, immagine 2 di 2
    • Remove the battery door and take out the batteries.
    Chiedi a FixBot
  3. VTech Learning Tunes Karaoke Speaker  Replacement: passo 3, immagine 1 di 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
    Chiedi a FixBot
  4. VTech Learning Tunes Karaoke Speaker  Replacement: passo 4, immagine 1 di 2 VTech Learning Tunes Karaoke Speaker  Replacement: passo 4, immagine 2 di 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Carefully place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
    Chiedi a FixBot
  5. VTech Learning Tunes Karaoke Speaker  Replacement: passo 5, immagine 1 di 2 VTech Learning Tunes Karaoke Speaker  Replacement: passo 5, immagine 2 di 2
    • Remove two 7.9 mm Phillips #1 screws on the speaker cover.
    • After removing the screws, remove the black plastic speaker cover to expose the speaker.
    Chiedi a FixBot
  6. VTech Learning Tunes Karaoke Speaker  Replacement: passo 6, immagine 1 di 1
    • Desolder the speaker at the solder points to remove.
    • Learn more about soldering and desoldering connections here.
    Chiedi a FixBot
Conclusione
USF Tampa, Team 7-2, Cheng Spring 2016 Membro di USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 48
Tutti i Tempi: 1,020
