Salta al contenuto principale
VTech InnoTab 2 Headphone Jack Replacement
Cosa ti serve
  1. VTech InnoTab 2 Headphone Jack Replacement, Battery: passo 1, immagine 1 di 3 VTech InnoTab 2 Headphone Jack Replacement, Battery: passo 1, immagine 2 di 3 VTech InnoTab 2 Headphone Jack Replacement, Battery: passo 1, immagine 3 di 3
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
  2. VTech InnoTab 2 Headphone Jack Replacement, Back Panel: passo 2, immagine 1 di 3 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: passo 2, immagine 2 di 3 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: passo 2, immagine 3 di 3
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
  3. VTech InnoTab 2 Headphone Jack Replacement: passo 3, immagine 1 di 3 VTech InnoTab 2 Headphone Jack Replacement: passo 3, immagine 2 di 3 VTech InnoTab 2 Headphone Jack Replacement: passo 3, immagine 3 di 3
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  4. VTech InnoTab 2 Headphone Jack Replacement: passo 4, immagine 1 di 2 VTech InnoTab 2 Headphone Jack Replacement: passo 4, immagine 2 di 2
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
  5. VTech InnoTab 2 Headphone Jack Replacement: passo 5, immagine 1 di 2 VTech InnoTab 2 Headphone Jack Replacement: passo 5, immagine 2 di 2
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
  6. VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: passo 6, immagine 1 di 3 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: passo 6, immagine 2 di 3 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: passo 6, immagine 3 di 3
    • Remove the two 7 mm screws from the left bumper of the device using a JO screwdriver.
    • Be careful not to pull to hard when removing the bumper to avoid damage to the circuit.
  7. VTech InnoTab 2 Headphone Jack Replacement: passo 7, immagine 1 di 3 VTech InnoTab 2 Headphone Jack Replacement: passo 7, immagine 2 di 3 VTech InnoTab 2 Headphone Jack Replacement: passo 7, immagine 3 di 3
    • Use your fingers to gently remove the headphone jack.
    • De-solder the points shown to fully remove the headphone jack from the motherboard.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills
Conclusione
USF Tampa, Team S1-G85, Cagle Fall 2017 Membro di USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 211
