Introduzione
During this guide, the base will need to be disassembled and then desolder the charging wire connections.
Cosa ti serve
Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
Refer to How to Solder and Desolder connections Come saldare e dissaldare componenti elettrici
