Salta al contenuto principale
Updating macOS With OpenCore Guide #4
Cosa ti serve
  1. Updating macOS With OpenCore Guide #4, Updating macOS With OpenCore Guide #4: passo 1, immagine 1 di 1
    • Okay, the big moment. It is time to update macOS using OpenCore.
  2. Updating macOS With OpenCore Guide #4: passo 2, immagine 1 di 1
    • First, we need to create a bootable USB drive for macOS.
    • Fortunately, there is a guide that covers how to do this:
    • Creare una chiavetta USB avviabile
    • Make sure you know which version of macOS you want to use.
    • If you want an older version of macOS (i.e. High Sierra), this guide, nor the guide above will not work. Soon I will make a guide covering how to install older versions of macOS using OpenCore.
  3. Updating macOS With OpenCore Guide #4: passo 3, immagine 1 di 1
    • Once you have created the Bootable USB Drive, made a backup of everything, and have successfully installed OpenCore on your Mac, you are ready to continue.
    • Restart your Mac, and hold down the Option (alt) key on your Mac.
    • In Startup Manager, you will see the OpenCore logo, and it will say "EFI Boot"
    • When booting into the OpenCore OCLP boot picker, your Mac will boot into it by default on every restart.
  4. Updating macOS With OpenCore Guide #4: passo 4, immagine 1 di 1
    • Ah, at last. The OpenCore OCLP Boot Menu. As you may notice, this Menu looks very similar to Startup Manager.
    • In this menu, you will see your Internal Drive (Probably Macintosh HD) and your USB drive you just created. That's where we want to boot. Choose the USB drive, and click the arrow to boot.
  5. Updating macOS With OpenCore Guide #4: passo 5, immagine 1 di 2 Updating macOS With OpenCore Guide #4: passo 5, immagine 2 di 2
    • If you see the Apple Logo, and then the progress bar, you are in good hands.
    • But, if you see the Prohibitory Sign, you will need to Spoof your Mac's Serial ID. This is extremely rare, and run back to Guide #3 to make sure you installed OpenCore correctly.
    • Once again, I will soon make a guide covering OpenCore's Post-Installation. That will cover Spoofing, Feature Unlock, Customizing the OCLP Picker, etc.
  6. Updating macOS With OpenCore Guide #4: passo 6, immagine 1 di 1
    • Once the Apple Logo goes away, you will be greeted by Recovery OS.
  7. Updating macOS With OpenCore Guide #4: passo 7, immagine 1 di 1
    • Now, the rest is easy, simply click on "Install or Upgrade macOS"
    • Click "Continue"
    • Click "Agree" and then "Agree" again.
    • Choose your Mac's drive, and click "Install"
    • Now, this installation could take anywhere from 25 minutes to 3 hours. So, sit back, and wait for your Mac to finish the installation.
  8. Updating macOS With OpenCore Guide #4: passo 8, immagine 1 di 1
    • Your Mac is going to Reboot several times.
    • If for some odd reason your Mac boots into Recovery OS after preparing the installation, simply reboot the Mac, and choose "macOS Install" in the OCLP Menu.
  9. Updating macOS With OpenCore Guide #4: passo 9, immagine 1 di 1
    • Eventually, you will see Setup Assistant. There, you can log into your iCloud account, and finish setting up anything else on your Mac.
  10. Updating macOS With OpenCore Guide #4: passo 10, immagine 1 di 1
    • One last step, we need to install any patches for your Mac.
    • Open up the OpenCore-Patcher app (Probably still in your Downloads folder), and you will see a button available: Post-Install Root Patch.
    • Click that button, and OpenCore will search for aplicable root patches (Graphics Driver, Bluetooth, USB, etc.)
    • Once all patches are found, click on "Start Root Patching"
    • OpenCore will close and then ask for your Username and Password. OpenCore will automatically relaunch as root.
  11. Updating macOS With OpenCore Guide #4: passo 11, immagine 1 di 1
    • When OpenCore relaunches, you will see a bunch of text scroll through rapidly.
    • Eventually, a new window will apear asking to reboot. Click the "Reboot" button, and then "Restart" in the power menu. After your Mac reboots, all patches will have been applied, and your Mac will be ready to roll.
  12. Updating macOS With OpenCore Guide #4: passo 12, immagine 1 di 1
    • Please note your Mac is probably not completely ready. You will still have to make sure OpenCore is installed on your Mac's internal Hard Drive.
    • To make booting a bit more snappy, open the OpenCore app once more, and uncheck "Show OpenCore Boot Picker" That way, your Mac will immediately boot without showing the OCLP menu at every startup.
    • And, if you migrate macOS later on, revert all root patches, and then migrate. This will prevent any kernel panics that may occur later on.
  13. Updating macOS With OpenCore Guide #4: passo 13, immagine 1 di 1
    • At this point, you should be able to eject your USB Drive, and you should be able to reboot into OpenCore without any Drives connected to your Mac.
    • Double check step three to make sure you choose the OpenCore OCLP while in Startup Manager.
Conclusione
All done! macOS is updated and you are ready to use your Mac. (Throughout this year, I will make mini guides explaining how to fix non-metal issues, manually root patching, etc.)
Jadon
Membro da: 09/05/23
1.973 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 60
Ultimi 30 Giorni: 252
Tutti i Tempi: 1,286
