Salta al contenuto principale
Uniden UTAB71 Battery Replacement
Cosa ti serve
  1. Uniden UTAB71 Battery Replacement, Battery: passo 1, immagine 1 di 2 Uniden UTAB71 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Use a plastic opening tool to undo the clips that attach the two halves of the tablet.
    • Be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Battery Replacement: passo 2, immagine 1 di 1
    • Lift off the tape that holds the speaker wires to the battery
    • Leave the tape off to the side
  3. Uniden UTAB71 Battery Replacement: passo 3, immagine 1 di 1
    • Use a soldering tool to disconnect the two wires (red and black) that connect the battery to the motherboard
    • Note the placement of each colored wire in the motherboard
    • If you have no experience in soldering, please follow this guide
  4. Uniden UTAB71 Battery Replacement: passo 4, immagine 1 di 2 Uniden UTAB71 Battery Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    iOpener
    $12.99
    Compra
    • Use a credit card to lift the battery off the back of the tablet
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery attached to the back panel with adhesive. You may need to use a heated iOpener to loosen the adhesive and remove the battery.
Conclusione
Ryan Jewell
Membro da: 10/20/16
422 Reputazione
4 Guide realizzate
UMass Dartmouth, Team 5-4, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 343
