Salta al contenuto principale
UTStarcom XV6700 Battery Replacement
Cosa ti serve
  1. UTStarcom XV6700 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Press the on/off button on the top to power the phone off.
  2. UTStarcom XV6700 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover by pressing and sliding the cover down and off of the phone.
  3. UTStarcom XV6700 Battery Replacement: passo 3, immagine 1 di 3 UTStarcom XV6700 Battery Replacement: passo 3, immagine 2 di 3 UTStarcom XV6700 Battery Replacement: passo 3, immagine 3 di 3
    • Pull the battery removal tab and lift the battery out of the phone.
    • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
Conclusione
1Commento della guida
it wont keep a charge, ive bought new battery and it will turn on load up. at main screen no longer than 10 seconds and shuts off.
jloizos79 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 376
