Salta al contenuto principale
Turtle Beach Recon 70P Microphone Replacement
Cosa ti serve
  1. Turtle Beach Recon 70P Microphone Replacement, Microphone: passo 1, immagine 1 di 2 Turtle Beach Recon 70P Microphone Replacement, Microphone: passo 1, immagine 2 di 2
    • Before continuing, remove the left ear pad with the earpad replacement guide.
    • Ensure that you are removing the side that houses the microphone.
    • Use a spudger to pry up the black plastic housing.
    • Remove the plastic cover.
  2. Turtle Beach Recon 70P Microphone Replacement: passo 2, immagine 1 di 3 Turtle Beach Recon 70P Microphone Replacement: passo 2, immagine 2 di 3 Turtle Beach Recon 70P Microphone Replacement: passo 2, immagine 3 di 3
    • Use a Phillips screwdriver remove the two 5 mm screws that secure the motherboard.
  3. Turtle Beach Recon 70P Microphone Replacement: passo 3, immagine 1 di 3 Turtle Beach Recon 70P Microphone Replacement: passo 3, immagine 2 di 3 Turtle Beach Recon 70P Microphone Replacement: passo 3, immagine 3 di 3
    • Use a Phillips screwdriver to remove the single 8 mm screw under the motherboard that secures the microphone.
  4. Turtle Beach Recon 70P Microphone Replacement: passo 4, immagine 1 di 3 Turtle Beach Recon 70P Microphone Replacement: passo 4, immagine 2 di 3 Turtle Beach Recon 70P Microphone Replacement: passo 4, immagine 3 di 3
    • You may need to move the wire connecting to the speaker to easily remove the motherboard.
    • Remove the circuit board from the housing.
    • Take care not to strain the wires.
  5. Turtle Beach Recon 70P Microphone Replacement: passo 5, immagine 1 di 1
    • Desolder the microphone connections.
    • Soldering irons can cause burns and fires. Always solder and desolder in a well-ventilated workspace.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 33
Tutti i Tempi: 536
