Salta al contenuto principale
Turtle Beach Ear Force P11 Speakers Replacement
Cosa ti serve
  1. Turtle Beach Ear Force P11 Speakers Replacement, Ear Cushion: passo 1, immagine 1 di 1
    • Pinch the inner edge of the ear cushion from the bottom.
  2. Turtle Beach Ear Force P11 Speakers Replacement: passo 2, immagine 1 di 1
    • Now slowly pull down the ear cushion as it completely separates from the speaker.
    • Carry out the pulling down action as slowly as possible or you might risk tearing the ear cushion otherwise
  3. Turtle Beach Ear Force P11 Speakers Replacement, Speakers: passo 3, immagine 1 di 1
    • Remove the 4 screws on the red speaker cover.
    • It is recommended to use a #000 Philips Screw Driver
  4. Turtle Beach Ear Force P11 Speakers Replacement: passo 4, immagine 1 di 2 Turtle Beach Ear Force P11 Speakers Replacement: passo 4, immagine 2 di 2
    • Inspect the wires for damage as illustrated
  5. Turtle Beach Ear Force P11 Speakers Replacement: passo 5, immagine 1 di 1
    • De-solder the speaker wires and remove the speaker.
    • Use low heat for de - soldering
  6. Turtle Beach Ear Force P11 Speakers Replacement: passo 6, immagine 1 di 1
    • Solder the new speaker wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • In case you use a large amount of solder, use a solder wick to absorb the excess solder.
    • You can find more information on "How To Solder" here:Come saldare e dissaldare componenti elettrici
Conclusione
Altre 4 persone hanno completato questa guida.
IUPUI, Team 1-2, Wilson Fall 2015 Membro di IUPUI, Team 1-2, Wilson Fall 2015
IUPUI-WILSON-F15S1G2
2 Membri
6 Guide realizzate
6 Commenti
can you fix mine contact me a jtrent238@outlook.com
jtrent238 - Replica
I am sorry jtrent238 , but i can further guide you on how you could solve the problem
Bhavesh Gandhi - Replica
If you look at step four you will see the black wire has a knot and a silver metal part. Well My wire has broken right there any advice? Please help!
Dev - Replica
Do you know where I can get the speakers from?
James Patrick - Replica
my problem exist in this area https://imgur.com/grLwOkt cant figure out how to detach the entire bud to get access to the internal wires
John - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 3,680
