Salta al contenuto principale
Turtle Beach Ear Force P11 Microphone Replacement
Cosa ti serve
  1. Turtle Beach Ear Force P11 Microphone Replacement, Microphone: passo 1, immagine 1 di 1
    • Remove the microphone cover by unscrewing the screw on the front side of the microphone.
    • It is recommended to use #000 Philips head screwdriver.
  2. Turtle Beach Ear Force P11 Microphone Replacement: passo 2, immagine 1 di 1
    • Use a nylon or metal spudger set to lift out the microphone.
    • Be careful lest you might break the fragile wires.
    • Always try using a plastic tool before resorting to a metal tool as shown in the picture.
  3. Turtle Beach Ear Force P11 Microphone Replacement: passo 3, immagine 1 di 1
    • De-solder the microphone wires and remove the microphone.
    • Use low heat for de - soldering
    • Do not cut the white and black wires soldered to the microphone as you might reduce the length of wire required to reassemble.
  4. Turtle Beach Ear Force P11 Microphone Replacement: passo 4, immagine 1 di 1
    • Solder the new microphone wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • You can find more information on How to Solder here: Come saldare e dissaldare componenti elettrici
    • To complete reassembly replace the cover taken off in step 1.
Conclusione
IUPUI, Team 1-2, Wilson Fall 2015 Membro di IUPUI, Team 1-2, Wilson Fall 2015
IUPUI-WILSON-F15S1G2
2 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,070
