Salta al contenuto principale
Tungsten E Battery Replacement
Cosa ti serve
  1. Tungsten E Battery Replacement, Battery: passo 1, immagine 1 di 1
  2. Tungsten E Battery Replacement: passo 2, immagine 1 di 1
    • Begin to pry up the battery. It is fastened to the mother board using two sided tape.
    • Caution: the battery is connected by two wires.
  3. Tungsten E Battery Replacement: passo 3, immagine 1 di 1
    • Remove the battery
    • Caution: Be careful not to tear the wires when removing battery.
  4. Tungsten E Battery Replacement: passo 4, immagine 1 di 1
    • Using a soldering iron, disconnect the battery wires.
    • Note: the wires are soldered to the board.
  5. Tungsten E Battery Replacement: passo 5, immagine 1 di 1
    • Take replacement battery and solder the wires to the board.
    • Take care to match wire colors as before.
    • Use double sided tape to attach battery firmly to board.
Conclusione
Kathleen Hix
Membro da: 01/21/10
49 Reputazione
2 Guide realizzate
Cal Poly, Team 13-22, Maness Winter 2010 Membro di Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 6,829
