Introduzione
If the speaker on your Trio Stealth-10 is no longer functioning, replacement isn't difficult and this guide will give you the step by step procedure to do so.
Cosa ti serve
To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
Next you must solder off the wires that connect the speaker to the motherboard.
