Salta al contenuto principale
Toyota Tacoma Bed Light Replacement
Cosa ti serve
  1. Toyota Tacoma Bed Light Replacement, Side Bed Light: passo 1, immagine 1 di 1
    • Open the hood by using the hood release lever located on the driver's side below the dashboard.
  2. Toyota Tacoma Bed Light Replacement: passo 2, immagine 1 di 2 Toyota Tacoma Bed Light Replacement: passo 2, immagine 2 di 2
    • Open the hood of the truck using the hood release mechanism located towards the center of the truck.
    • Lift the prop and place it in its designated hole in the hood.
  3. Toyota Tacoma Bed Light Replacement: passo 3, immagine 1 di 3 Toyota Tacoma Bed Light Replacement: passo 3, immagine 2 di 3 Toyota Tacoma Bed Light Replacement: passo 3, immagine 3 di 3
    • The battery is located on the driver's side of the engine compartment.
    • Loosen the 11mm nut on the collar holding the black wire to the negative terminal of the battery.
    • Lift up vertically on the wire and remove it from the battery contact pin.
  4. Toyota Tacoma Bed Light Replacement: passo 4, immagine 1 di 3 Toyota Tacoma Bed Light Replacement: passo 4, immagine 2 di 3 Toyota Tacoma Bed Light Replacement: passo 4, immagine 3 di 3
    • Get underneath the truck at this location.
    • Cut the red wire in the space between the fender and the bed using a wire cutter.
  5. Toyota Tacoma Bed Light Replacement: passo 5, immagine 1 di 1
    • Open the bed to gain access to the broken light.
  6. Toyota Tacoma Bed Light Replacement: passo 6, immagine 1 di 2 Toyota Tacoma Bed Light Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the two screws holding the light enclosure to the bed.
  7. Toyota Tacoma Bed Light Replacement: passo 7, immagine 1 di 2 Toyota Tacoma Bed Light Replacement: passo 7, immagine 2 di 2
    • Remove the rubber backing on the light enclosure.
  8. Toyota Tacoma Bed Light Replacement: passo 8, immagine 1 di 1
    • Place the rubber backing on the new light enclosure.
  9. Toyota Tacoma Bed Light Replacement: passo 9, immagine 1 di 2 Toyota Tacoma Bed Light Replacement: passo 9, immagine 2 di 2
    • Wire the new enclosure's terminal leads through the hole in the bed.
    • Check underneath of bed to ensure that the wires are hanging freely below the bed in the same area as the wires in step 4.
  10. Toyota Tacoma Bed Light Replacement: passo 10, immagine 1 di 2 Toyota Tacoma Bed Light Replacement: passo 10, immagine 2 di 2
    • Put blue locktite on screws to keep them in place.
    • Screw new enclosure into place using a Phillips #2 screwdriver.
  11. Toyota Tacoma Bed Light Replacement: passo 11, immagine 1 di 3 Toyota Tacoma Bed Light Replacement: passo 11, immagine 2 di 3 Toyota Tacoma Bed Light Replacement: passo 11, immagine 3 di 3
    • Cut the new leads to the desired length underneath the truck.
    • Strip the wires using a wire stripper.
  12. Toyota Tacoma Bed Light Replacement: passo 12, immagine 1 di 1
    • Wrap the exposed ends of the wires together, being sure to only connect alike colors.
  13. Toyota Tacoma Bed Light Replacement: passo 13, immagine 1 di 2 Toyota Tacoma Bed Light Replacement: passo 13, immagine 2 di 2
  14. Toyota Tacoma Bed Light Replacement: passo 14, immagine 1 di 2 Toyota Tacoma Bed Light Replacement: passo 14, immagine 2 di 2
    • Wrap the exposed wire in electrical tape to protect against the elements.
  15. Toyota Tacoma Bed Light Replacement: passo 15, immagine 1 di 3 Toyota Tacoma Bed Light Replacement: passo 15, immagine 2 di 3 Toyota Tacoma Bed Light Replacement: passo 15, immagine 3 di 3
    • Reconnect the negative lead to the battery.
    • Tighten the collar using an 11mm wrench.
    • Close hood ensuring that the prop is placed in the designated clip.
  16. Toyota Tacoma Bed Light Replacement: passo 16, immagine 1 di 2 Toyota Tacoma Bed Light Replacement: passo 16, immagine 2 di 2
    • Test the new light by flipping the switch on the dashboard of the truck.
Conclusione
Thank you
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 48
Tutti i Tempi: 2,208
