Salta al contenuto principale
Toshiba Tecra M2 CPU Replacement
Cosa ti serve
  1. Toshiba Tecra M2 CPU Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop upside down so the back compartment is facing up.
    • Place left thumb on the battery lock tab.
    • Place right thumb on the battery release latch.
  2. Toshiba Tecra M2 CPU Replacement: passo 2, immagine 1 di 2 Toshiba Tecra M2 CPU Replacement: passo 2, immagine 2 di 2
    • Slide both tabs outward at the same time to release battery pack.
  3. Toshiba Tecra M2 CPU Replacement: passo 3, immagine 1 di 1
    • Pull out the battery after it has popped out and set aside.
    • The battery and the battery cover are in one piece
  4. Toshiba Tecra M2 CPU Replacement, CPU: passo 4, immagine 1 di 1
    • Use a #00 phillips head screwdriver to remove the 8mm screw for the keyboard strip located under the battery.
  5. Toshiba Tecra M2 CPU Replacement: passo 5, immagine 1 di 1
    • Turn the device over and open it up to the display.
    • Gently lift a corner of the keyboard strip until it pops out of its position.
  6. Toshiba Tecra M2 CPU Replacement: passo 6, immagine 1 di 1
    • Using a #00 phillips head screwdriver, remove the two 4mm screws found underneath the keyboard strip.
  7. Toshiba Tecra M2 CPU Replacement: passo 7, immagine 1 di 2 Toshiba Tecra M2 CPU Replacement: passo 7, immagine 2 di 2
    • Pop the keyboard up gently and rest on top of the touch pad
    • The keyboard is attached underneath by a thin film. Do not rip the keyboard off. Gently lay it down without ripping the film.
  8. Toshiba Tecra M2 CPU Replacement: passo 8, immagine 1 di 2 Toshiba Tecra M2 CPU Replacement: passo 8, immagine 2 di 2
    • Using a #00 phillips head screwdriver, remove the 6mm screw holding the metal plate down.
  9. Toshiba Tecra M2 CPU Replacement: passo 9, immagine 1 di 2 Toshiba Tecra M2 CPU Replacement: passo 9, immagine 2 di 2
    • Gently remove the keyboard connector film from the motherboard with fingers by lifting upwards.
    • Set aside the keyboard.
  10. Toshiba Tecra M2 CPU Replacement: passo 10, immagine 1 di 1
    • Using a #00 phillips head screwdriver, remove the three 13mm screws holding down the touch pad's frame from underneath the keyboard.
  11. Toshiba Tecra M2 CPU Replacement: passo 11, immagine 1 di 3 Toshiba Tecra M2 CPU Replacement: passo 11, immagine 2 di 3 Toshiba Tecra M2 CPU Replacement: passo 11, immagine 3 di 3
    • Flip laptop back upside down.
    • Remove the 5mm lock screw, using a #00 phillips head screwdriver.
    • Slide bay latch toward the battery compartment.
    • Remove CD-RW/DVD-ROM drive.
  12. Toshiba Tecra M2 CPU Replacement: passo 12, immagine 1 di 1
    • Remove the 4.5mm screw located under the CD-RW/DVD-ROM drive compartment, using a #00 phillips head screwdriver.
  13. Toshiba Tecra M2 CPU Replacement: passo 13, immagine 1 di 1
    • Remove the three 17mm screws found on the backside of the laptop using a #00 phillips head screwdriver.
    • Remove the ten 8mm screws using a #00 phillips head screwdriver.
  14. Toshiba Tecra M2 CPU Replacement: passo 14, immagine 1 di 2 Toshiba Tecra M2 CPU Replacement: passo 14, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Flip the laptop back over and unplug the touch pad's power cord from the motherboard gently using a pair of tweezers.
  15. Toshiba Tecra M2 CPU Replacement: passo 15, immagine 1 di 2 Toshiba Tecra M2 CPU Replacement: passo 15, immagine 2 di 2
    • Lift off the plastic cover and set it aside.
  16. Toshiba Tecra M2 CPU Replacement: passo 16, immagine 1 di 2 Toshiba Tecra M2 CPU Replacement: passo 16, immagine 2 di 2
    • Using a #00 phillips head screwdriver, unscrew the three 5mm screws holding down the heat sink securing bracket.
    • Lift off the securing bracket and set aside.
  17. Toshiba Tecra M2 CPU Replacement: passo 17, immagine 1 di 1
    • Wiggle the heat sink until it lifts off the top of your CPU. There is thermal paste underneath and it may stick.
  18. Toshiba Tecra M2 CPU Replacement: passo 18, immagine 1 di 3 Toshiba Tecra M2 CPU Replacement: passo 18, immagine 2 di 3 Toshiba Tecra M2 CPU Replacement: passo 18, immagine 3 di 3
    • Turn a flathead #3 screwdriver counter-clockwise to unlock the CPU socket.
    • Grab the CPU with your index finger and thumb and pull directly upwards.
    • Apply a new coat of thermal paste before reassembling.
    • Come applicare la Pasta Termica
Conclusione
Altre 2 persone hanno completato questa guida.
Cindy Nguyen
Membro da: 09/08/14
386 Reputazione
3 Guide realizzate
CSU Fullerton, Team 1-6, Bruce Fall 2014 Membro di CSU Fullerton, Team 1-6, Bruce Fall 2014
CSUF-BRUCE-F14S1G6
3 Membri
9 Guide realizzate
Un commento
"Step 4 - CPU" THAT IS NOT A 8MM SCREW! THERE IS NOW A HOLE IN MY COMPUTER!!
[deleted] - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,600
