Introduzione
The CPU cooling fan is simple to replace and may need to be removed if the motherboard is replaced.
Cosa ti serve
Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel.
Remove two 3.5 mm screws with a Phillips #0 screwdriver from either side of the fan.
