Salta al contenuto principale
Toshiba Satellite P55-A5312 Battery Replacement
Cosa ti serve
  1. Toshiba Satellite P55-A5312 Battery Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite P55-A5312 Battery Replacement, Battery: passo 1, immagine 2 di 2
  2. Toshiba Satellite P55-A5312 Battery Replacement: passo 2, immagine 1 di 2 Toshiba Satellite P55-A5312 Battery Replacement: passo 2, immagine 2 di 2
    • Locate the battery, which is in the top right hand corner of the laptop.
    • Remove all the 2.5x6mm screws that secure the battery with a Philips 00 screwdriver.
  3. Toshiba Satellite P55-A5312 Battery Replacement: passo 3, immagine 1 di 1
    • Locate the intersection of the wires that connect the battery to the motherboard.
    • Unplug these wires by gently pulling on the white plug, as shown in the picture.
  4. Toshiba Satellite P55-A5312 Battery Replacement: passo 4, immagine 1 di 1
    • Carefully remove the speaker that is placed above the battery by gently pulling upward from one end. Be careful not to break a wire.
    • Move the speaker elsewhere while replacing the battery (do not disconnect it).
  5. Toshiba Satellite P55-A5312 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the battery from the laptop after it has been completely disconnected.
Conclusione
Altre 5 persone hanno completato questa guida.
ohatae
Membro da: 01/25/17
294 Reputazione
2 Guide realizzate
Cal Poly, Team 9-1, Banghart Winter 2017 Membro di Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
3 Membri
6 Guide realizzate
Un commento
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
Roy Conrad - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 23
Tutti i Tempi: 5,973
