Salta al contenuto principale
Toshiba Satellite L50-B Keyboard / Palm Rest Replacement
Cosa ti serve
  1. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Verify the replacement part: passo 1, immagine 1 di 1
    • Visually check that the replacement keyboard is similar to the existing one.
  2. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Battery removal: passo 2, immagine 1 di 2 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Battery removal: passo 2, immagine 2 di 2
    • Unscrew the 2 upper screws using a PH1 Phillips screwdriver
    • Remove the battery by pulling it lengthwise
  3. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the lower case: passo 3, immagine 1 di 2 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the lower case: passo 3, immagine 2 di 2
    • Take out the 9 screws with a PH1 Phillips screwdriver.
    • Using a Spudger or an iFixit Opening Tool available on the iFixit store, remove the cover, taking care at the various attachment points.
  4. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Optical Drive: passo 4, immagine 1 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Optical Drive: passo 4, immagine 2 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Optical Drive: passo 4, immagine 3 di 3
    • Take a look at the connector to the motherboard, then pull the disk drive straight out away from it to remove it.
    • Take the optical drive out.
  5. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the SD Card Reader: passo 5, immagine 1 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the SD Card Reader: passo 5, immagine 2 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the SD Card Reader: passo 5, immagine 3 di 3
  6. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the hard drive: passo 6, immagine 1 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the hard drive: passo 6, immagine 2 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the hard drive: passo 6, immagine 3 di 3
    • Remove the plastic wedge that secures the hard drive in place.
    • Pull the hard drive away from the black connector to disconnect it from the motherboard.
    • Remove the hard drive.
  7. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the LED Status Board: passo 7, immagine 1 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the LED Status Board: passo 7, immagine 2 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the LED Status Board: passo 7, immagine 3 di 3
    • Disconnect up the cable connecting the LED status board to the motherboard. It is a ZIF connector.
    • Remove the screw using a PH1 Phillips screwdriver.
    • Remove the LED Status Board.
  8. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Ethernet / USB Board: passo 8, immagine 1 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Ethernet / USB Board: passo 8, immagine 2 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Ethernet / USB Board: passo 8, immagine 3 di 3
    • Disconnect the cable connecting the Ethernet / USB card to the motherboard. It is a ZIF type connector.
    • Remove the Ethernet / USB board.
  9. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the DC Power Cable: passo 9, immagine 1 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the DC Power Cable: passo 9, immagine 2 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the DC Power Cable: passo 9, immagine 3 di 3
  10. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnect the WiFi Card: passo 10, immagine 1 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnect the WiFi Card: passo 10, immagine 2 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnect the WiFi Card: passo 10, immagine 3 di 3
    • Disconnect the 2 antenna cables.
    • Pay attention to the colors when reconnecting the two cables during reassembly.
  11. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the WiFi Card: passo 11, immagine 1 di 2 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the WiFi Card: passo 11, immagine 2 di 2
    • Pull the card straight out away from the motherboard to remove it.
    • Take note of the cable routing for reassembly.
  12. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnect the Webcam Connector: passo 12, immagine 1 di 1
    • Unplug the webcam connector.
  13. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnect the Trackpad: passo 13, immagine 1 di 1
    • Unplug the ZIF connector on the trackpad securing the ribbon cable to the motherboard.
  14. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnect 4 connectors: passo 14, immagine 1 di 2 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnect 4 connectors: passo 14, immagine 2 di 2
    • Disconnect the ZIF connector on the power button board.
    • Unplug the LCD screen video cable.
    • Disconnect the two plugs indicated:
    • The speaker cable (left)
    • The fan cable (right)
  15. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the CPU Fan and Heat Sink: passo 15, immagine 1 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the CPU Fan and Heat Sink: passo 15, immagine 2 di 3 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the CPU Fan and Heat Sink: passo 15, immagine 3 di 3
    • Using a PH1 Phillips screwdriver, remove the two screws securing the CPU fan.
    • Remove the four screws holding the heat sink to the processor with a PH1 Phillips screwdriver.
    • Remove the fan and heatsink.
    • Use care when separating the heatsink from the CPU; it is bonded with thermal grease which may act as an adhesive when it is old.
    • Always replace the thermal grease when reinstalling the heat sink to ensure a good thermal bond between the CPU and the heat sink.
  16. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnect the Speakers: passo 16, immagine 1 di 2 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnect the Speakers: passo 16, immagine 2 di 2
    • Remove the 4 screws securing the speakers with a PH1 Phillips screwdriver.
  17. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnecting the Motherboard: passo 17, immagine 1 di 2 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Disconnecting the Motherboard: passo 17, immagine 2 di 2
    • Using a PH1 Phillips screwdriver, remove the four screws securing the motherboard to the chassis.
    • Remove the cable connecting the keyboard to the motherboard. Lift the tape holding the cable to the connector, then use a spudger to press out the two small tabs on either side of the cable side connector in a walking motion, alternating one side then the other.
  18. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Motherboard: passo 18, immagine 1 di 1
    • Remove the motherboard, taking care with the speaker cables, the various cables, and any fasteners bordering the sides of the motherboard.
  19. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Speakers: passo 19, immagine 1 di 2 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Speakers: passo 19, immagine 2 di 2
    • Remove the speakers, taking care with the cable retainers, and any Scotch tape securing the cables to the chassis.
  20. Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Display Hinges: passo 20, immagine 1 di 2 Toshiba Satellite L50-B Keyboard / Palm Rest Replacement, Remove the Display Hinges: passo 20, immagine 2 di 2
    • Unscrew the two screws on each hinge using a PH1 Phillips screwdriver.
    • To easily remove the hinges, raise the them by hand as if you were opening the screen in order to remove the them from the upper case.
    • Use a hair dryer, heat gun or iOpener to soften the adhesive that attaches the Trackpad to the upper case.
    • Press on the trackpad to unstick it and separate it from the case.
    • Too much head risks melting the micro-welds on the Trackpad, so be cautious with the use of a heat gun.
    • Be careful not to damage the Trackpad when taking it off. Although it is a relatively solid part, the glue is present on a large part of its surface and is strongly adhered. You can see the adhesive strip on a new part.
Conclusione
Congratulations! You have completed the disassembly!
To reassemble your device, follow the instructions in reverse, using the new keyboard assembly instead of the old one.
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Arnaud Milesi
Membro da: 11/21/16
323 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 54
Tutti i Tempi: 2,888
