Salta al contenuto principale
Toshiba Satellite L15W-B1320 Battery Replacement
Cosa ti serve
  1. Toshiba Satellite L15W-B1320 Battery Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite L15W-B1320 Battery Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite L15W-B1320 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Battery Replacement: passo 2, immagine 1 di 3 Toshiba Satellite L15W-B1320 Battery Replacement: passo 2, immagine 2 di 3 Toshiba Satellite L15W-B1320 Battery Replacement: passo 2, immagine 3 di 3
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,335
