Salta al contenuto principale
Toshiba Satellite A210 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite A210 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A210 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite A210 Keyboard Replacement: passo 2, immagine 2 di 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  4. Toshiba Satellite A210 Keyboard Replacement: passo 4, immagine 1 di 3 Toshiba Satellite A210 Keyboard Replacement: passo 4, immagine 2 di 3 Toshiba Satellite A210 Keyboard Replacement: passo 4, immagine 3 di 3
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  5. Toshiba Satellite A210 Keyboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite A210 Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  6. Toshiba Satellite A210 Keyboard Replacement: passo 6, immagine 1 di 1
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Youlen
Membro da: 04/11/13
49 Reputazione
2 Guide realizzate
Cal Poly, Team 17-5, Regan Spring 2013 Membro di Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Membri
18 Guide realizzate
Un commento
very useful. THANKS
ANDREAS - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,678
