Salta al contenuto principale
Toshiba Equium M70 Faulty Graphics
Cosa ti serve
  1. Toshiba Equium M70 Faulty Graphics, Toshiba Equium M70 Faulty Graphics: passo 1, immagine 1 di 1
    • This is a complete top half strip down to fix (takes me less than 30 minutes)
  2. Toshiba Equium M70 Faulty Graphics: passo 2, immagine 1 di 1
    • this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
  3. Toshiba Equium M70 Faulty Graphics: passo 3, immagine 1 di 1
    • cut a thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
  4. Toshiba Equium M70 Faulty Graphics: passo 4, immagine 1 di 1
    • Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
  5. Toshiba Equium M70 Faulty Graphics: passo 5, immagine 1 di 1
    • THen apply more thermal paste to the top of the shim
  6. Toshiba Equium M70 Faulty Graphics: passo 6, immagine 1 di 1
    • The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
  7. Toshiba Equium M70 Faulty Graphics: passo 7, immagine 1 di 1
    • This is the CPU with the new alloy shim fitted.
Conclusione
Altre 3 persone hanno completato questa guida.
Terry Sim
Membro da: 02/12/11
207 Reputazione
1 Guida realizzata
Un commento
Pros: Very good hi-res pictures, well explained.
Cons: The disassembly instructions are missing
Nicola Nascimento - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,086
