Salta al contenuto principale
Titan Airless Sprayer IMPACT 410 Capacitor Replacement
Cosa ti serve
  1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: passo 1, immagine 1 di 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: passo 2, immagine 1 di 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: passo 2, immagine 2 di 2
    • Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
  3. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: passo 3, immagine 1 di 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: passo 3, immagine 2 di 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: passo 3, immagine 3 di 3
    • Pull the motor cover straight off the motor.
  4. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: passo 4, immagine 1 di 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: passo 4, immagine 2 di 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: passo 4, immagine 3 di 3
    • Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
    • During reassembly, replace the cable ties.
  5. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: passo 5, immagine 1 di 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: passo 5, immagine 2 di 2
    • Disconnect the black negative wire's spade connector.
    • Always grip cables by their connectors and not the wires themselves.
  6. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: passo 6, immagine 1 di 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: passo 6, immagine 2 di 2
    • Disconnect the red positive wire's bullet connector.
  7. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: passo 7, immagine 1 di 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: passo 7, immagine 2 di 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: passo 7, immagine 3 di 3
    • Grip the cable tie and slide it off the capacitors.
  8. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Discharge the capacitors: passo 8, immagine 1 di 1
    • If you have already discharged the capacitors, skip this step.
    • Follow this guide to discharge your capacitors.
  9. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: passo 9, immagine 1 di 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: passo 9, immagine 2 di 2
    • The capacitors are lightly adhered to the motor body.
    • Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
    • Pry up to separate the bottom cell from the motor body.
  10. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: passo 10, immagine 1 di 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: passo 10, immagine 2 di 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: passo 10, immagine 3 di 3
    • Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
    • Pry up to separate the rest of the capacitor from the motor body.
    • Remove the capacitor.
    • During reassembly, if the adhesive is no longer sticky, replace it with double-sided foam adhesive.
Conclusione
Alex Diaz-Kokaisl
Membro da: 01/16/22
124.612 Reputazione
582 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.299 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 287
