Salta al contenuto principale
The Sharper Image Literati Tablet SD Port Replacement
Cosa ti serve
  1. The Sharper Image Literati Tablet SD Port Replacement, Battery: passo 1, immagine 1 di 1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet SD Port Replacement: passo 2, immagine 1 di 1
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet SD Port Replacement: passo 3, immagine 1 di 1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet SD Port Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
  5. The Sharper Image Literati Tablet SD Port Replacement, SD Port: passo 5, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  6. The Sharper Image Literati Tablet SD Port Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
  7. The Sharper Image Literati Tablet SD Port Replacement: passo 7, immagine 1 di 1
    • Remove the circuit board.
  8. The Sharper Image Literati Tablet SD Port Replacement: passo 8, immagine 1 di 1
    • Unclip ZIF clip from the chip and unplug ribbon cable.
  9. The Sharper Image Literati Tablet SD Port Replacement: passo 9, immagine 1 di 1
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
  10. The Sharper Image Literati Tablet SD Port Replacement: passo 10, immagine 1 di 1
    • Remove peripheral silver edge.
  11. The Sharper Image Literati Tablet SD Port Replacement: passo 11, immagine 1 di 1
    • Remove screws from the large metal shielding.
  12. The Sharper Image Literati Tablet SD Port Replacement: passo 12, immagine 1 di 1
    • Remove the silver backing plate and the adhered SD port chip.
Conclusione
IUPUI, Team S5-G4, Baechle Spring 2018 Membro di IUPUI, Team S5-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G4
3 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 346
