Salta al contenuto principale
The Sharper Image Literati Tablet Battery Replacement
Cosa ti serve
  1. The Sharper Image Literati Tablet Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet Battery Replacement: passo 2, immagine 1 di 1
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet Battery Replacement: passo 3, immagine 1 di 1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet Battery Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
Linea Traguardo
IUPUI, Team S5-G4, Baechle Spring 2018 Membro di IUPUI, Team S5-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G4
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 811
