Salta al contenuto principale
Texas Instruments TI-30X IIS Solar Panel Replacement
Cosa ti serve
  1. Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: passo 1, immagine 1 di 2 Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: passo 1, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the four 5 mm screws securing the back panel.
  2. Texas Instruments TI-30X IIS Solar Panel Replacement: passo 2, immagine 1 di 1
    • Wedge an opening tool in the gap between the front and back panel, then gently pry until the tabs release.
  3. Texas Instruments TI-30X IIS Solar Panel Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the two 3 mm screws securing the motherboard.
  4. Texas Instruments TI-30X IIS Solar Panel Replacement: passo 4, immagine 1 di 1
    • Desoldering and soldering presents a potential for device damage. Always solder/desolder in well-ventilated environments and with care not to burn yourself.
    • Desolder the positive the negative terminals on the motherboard.
  5. Texas Instruments TI-30X IIS Solar Panel Replacement: passo 5, immagine 1 di 2 Texas Instruments TI-30X IIS Solar Panel Replacement: passo 5, immagine 2 di 2
    • Gently lift up the front of the motherboard, at the top of the calculator.
    • Desolder the positive and negative terminals on the solar panel
    • Use the tip of a spudger to "walk" the solar panel out of its housing, by pushing it down through the two cutouts until it slides out of the bottom.
    • Remove the solar panel.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 46
Tutti i Tempi: 861
