Salta al contenuto principale
Teddy Ruxpin Mouth Replacement
Cosa ti serve
  1. Teddy Ruxpin Mouth Replacement, Battery: passo 1, immagine 1 di 2 Teddy Ruxpin Mouth Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Mouth Replacement: passo 2, immagine 1 di 1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Mouth Replacement: passo 3, immagine 1 di 1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Mouth Replacement, Arms: passo 4, immagine 1 di 3 Teddy Ruxpin Mouth Replacement, Arms: passo 4, immagine 2 di 3 Teddy Ruxpin Mouth Replacement, Arms: passo 4, immagine 3 di 3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Mouth Replacement: passo 5, immagine 1 di 1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Mouth Replacement: passo 6, immagine 1 di 3 Teddy Ruxpin Mouth Replacement: passo 6, immagine 2 di 3 Teddy Ruxpin Mouth Replacement: passo 6, immagine 3 di 3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Mouth Replacement: passo 7, immagine 1 di 2 Teddy Ruxpin Mouth Replacement: passo 7, immagine 2 di 2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Mouth Replacement: passo 8, immagine 1 di 2 Teddy Ruxpin Mouth Replacement: passo 8, immagine 2 di 2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Mouth Replacement: passo 9, immagine 1 di 1
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Mouth Replacement, Housing Cover: passo 10, immagine 1 di 3 Teddy Ruxpin Mouth Replacement, Housing Cover: passo 10, immagine 2 di 3 Teddy Ruxpin Mouth Replacement, Housing Cover: passo 10, immagine 3 di 3
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Mouth Replacement, Eyes: passo 11, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
  12. Teddy Ruxpin Mouth Replacement: passo 12, immagine 1 di 2 Teddy Ruxpin Mouth Replacement: passo 12, immagine 2 di 2
    • Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
  13. Teddy Ruxpin Mouth Replacement: passo 13, immagine 1 di 1
    • Once those wires are disconnected, desolder the wires connected from the eye motherboard.
  14. Teddy Ruxpin Mouth Replacement, Mouth: passo 14, immagine 1 di 2 Teddy Ruxpin Mouth Replacement, Mouth: passo 14, immagine 2 di 2
    • Remove five 12.5mm Phillips #1 screws.
    • Pull the mouth mechanism out of the shell.
  15. Teddy Ruxpin Mouth Replacement: passo 15, immagine 1 di 2 Teddy Ruxpin Mouth Replacement: passo 15, immagine 2 di 2
    • Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
    • Open the mouth mechanism
Conclusione
Jayin Patel
Membro da: 01/23/20
406 Reputazione
4 Guide realizzate
Cal Poly, Team S18-G5, White Winter 2020 Membro di Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 Membri
7 Guide realizzate
3 Commenti
His mouth and nose fell out leaving a hole in his face. How do i fix it or is the repair shop local? He is 30 years old.
rrhall559 - Replica
Mouth and nose fellout
rrhall559 - Replica
World of wonder made it and they aren’t in business anymore
rrhall559 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,408
