Introduzione
Teddy Ruxpin’s eyes are LED and will react to story-time. If the eyes are glitching, not turning on, or malfunctioning in any way, follow this guide to replace them. Be cautious during desoldering and keep track of screws. Refer to the desoldering guide for help.
Cosa ti serve
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
Unscrew the eleven circled 12.5mm Phillips #1 screws.
Remove the top of the housing to access the electronics inside.
Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
Altre 2 persone hanno completato questa guida.
