Salta al contenuto principale
TaoTronics TT-SK06 Aux Port Replacement
Cosa ti serve
  1. TaoTronics TT-SK06 Aux Port Replacement, Front Grate: passo 1, immagine 1 di 2 TaoTronics TT-SK06 Aux Port Replacement, Front Grate: passo 1, immagine 2 di 2
    • To remove the front grate of the speaker grab a metal spudger and go to the back corner of the device where the front panel curves around the device. Insert the spudger and ply apart the corner until clips release from panel. Repeat for the other side of the grate. When all clips are released pull grate off from the front of device
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  2. TaoTronics TT-SK06 Aux Port Replacement: passo 2, immagine 1 di 3 TaoTronics TT-SK06 Aux Port Replacement: passo 2, immagine 2 di 3 TaoTronics TT-SK06 Aux Port Replacement: passo 2, immagine 3 di 3
    • Grab two metal spudgers and insert one into the slit underneath the silver plating on the top of the device. Pry upward with the spudger until you unhook the two locks on the top. Repeat same step for the bottom of the device. When all four tabs are released, slide device out of the casing
    • Use caution when working with the metal spudger, as it can potentially damage your device.
  3. TaoTronics TT-SK06 Aux Port Replacement, Aux Port: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove the circuit board containing the aux port using the tweezers.
  4. TaoTronics TT-SK06 Aux Port Replacement: passo 4, immagine 1 di 1
    • Remove the aux port from the board by un-soldering the connection points.
    • To reattach, solder aux port back onto board. For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
Conclusione
Altre 2 persone hanno completato questa guida.
Niko Fabian
Membro da: 03/06/16
715 Reputazione
5 Guide realizzate
1Commento della guida
I wanted to completely disassemble the speaker to see if I could modify its power source (from battery to USB). but found it glued shut. There are screws that would seem to open up the internals, but removing the screws did nothing. In the end I put it back together, and decided to not replace any of the screws. The glue and metal case are sufficient. No screws necessary.
I would prefer it to not power down while using USB power, but destroying the speaker to convert it to USB power is not the answer.
Michael Johnstone - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,014
