Salta al contenuto principale
TECHUP Bluetooth Speaker Motherboard Replacement
Cosa ti serve
  1. TECHUP Bluetooth Speaker Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Pry the foam buffer from the speaker using a nylon spudger or flathead screwdriver (pictured).
    • You will need to re-apply adhesive if you want to reattach this foam after removing it.
  2. TECHUP Bluetooth Speaker Motherboard Replacement: passo 2, immagine 1 di 3 TECHUP Bluetooth Speaker Motherboard Replacement: passo 2, immagine 2 di 3 TECHUP Bluetooth Speaker Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the two bottom screws using a Phillips #0 screwdriver.
  3. TECHUP Bluetooth Speaker Motherboard Replacement: passo 3, immagine 1 di 2 TECHUP Bluetooth Speaker Motherboard Replacement: passo 3, immagine 2 di 2
    • Pull the plastic casing away from the speaker.
    • You may have to twist-and-pull to remove it.
  4. TECHUP Bluetooth Speaker Motherboard Replacement: passo 4, immagine 1 di 2 TECHUP Bluetooth Speaker Motherboard Replacement: passo 4, immagine 2 di 2
    • Desolder the two battery wires from the motherboard.
    • Because you are dealing with battery connections, be aware of the shock hazard.
  5. TECHUP Bluetooth Speaker Motherboard Replacement: passo 5, immagine 1 di 2 TECHUP Bluetooth Speaker Motherboard Replacement: passo 5, immagine 2 di 2
    • Desolder the two speaker wires from the motherboard.
  6. TECHUP Bluetooth Speaker Motherboard Replacement: passo 6, immagine 1 di 1
    • Grasp the motherboard and pull it from the encasement.
    • Take care to not rip the wires as you pull the motherboard out, as they may catch in the grooves on the motherboard.
  7. TECHUP Bluetooth Speaker Motherboard Replacement: passo 7, immagine 1 di 1
    • Pry the battery from the motherboard using a nylon spudger.
    • You may have to apply significant force to the motherboard to remove the battery.
    • Always use an ESD-safe tool, such as a nylon spudger, when working with batteries. Metal tools can puncture an unprotected battery, potentially causing a fire.
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 80
Tutti i Tempi: 2,616
