Salta al contenuto principale
System76 Serval WS Cooling Fan Replacement
Cosa ti serve
  1. System76 Serval WS Cooling Fan Replacement, Cooling Fan: passo 1, immagine 1 di 1
    • Unplug the power supply and remove the battery from the device before proceeding.
    • Unscrew and remove the 4 screws circled in red. Then remove the plastic bottom panel.
  2. System76 Serval WS Cooling Fan Replacement: passo 2, immagine 1 di 2 System76 Serval WS Cooling Fan Replacement: passo 2, immagine 2 di 2
    • Remove the numbered screws in order to safely remove the heatsink
    • Remove the heatsink to access the cooling fans.
    • During reassembly, make sure to tighten the heatsink screws in the order indicated by the labeled numbers.
  3. System76 Serval WS Cooling Fan Replacement: passo 3, immagine 1 di 1
    • Unscrew and remove the screws circled in red, 3 screws per fan.
    • Next unplug the 4-pin power connectors, marked in orange squares.
    • Remove the cooling fans by lifting them up and out of the casing.
  4. System76 Serval WS Cooling Fan Replacement: passo 4, immagine 1 di 2 System76 Serval WS Cooling Fan Replacement: passo 4, immagine 2 di 2
    • Plug in the 4-pin power connectors of the new fans.
    • Insert and tighten 3 screws per fan.
    • If needed, clean off the old thermal paste from the CPU, GPU, and heatsink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Clean the dust from the heatsink fins.
Conclusione
Oliver Anderson
Membro da: 03/26/19
289 Reputazione
3 Guide realizzate
Un commento
What model of fan would one buy to replace this?
CrustyTrombone - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 624
