Salta al contenuto principale
Swagtron T3 Cover Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Swagtron T3 Cover Replacement, Cover: passo 1, immagine 1 di 2 Swagtron T3 Cover Replacement, Cover: passo 1, immagine 2 di 2
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
  2. Swagtron T3 Cover Replacement: passo 2, immagine 1 di 3 Swagtron T3 Cover Replacement: passo 2, immagine 2 di 3 Swagtron T3 Cover Replacement: passo 2, immagine 3 di 3
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
Conclusione
Cal Poly, Team S13-G3, Forte Spring 2017 Membro di Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 32
Tutti i Tempi: 5,127
