Introduzione
Follow this guide to replace your power supply unit
Cosa ti serve
Lay the Surface face down on a padded surface
Remove the four rubber feet at each corner concealing the Torx screws
Remove the four Torx screws under the rubber feet.
Two screws on the upper corners are longer than two screws on the lower corners.
Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
Altre 5 persone hanno completato questa guida.
3 Commenti
Does anyone have a source for a new power supply?
