Introduzione
This guide shows you how to replace the motherboard in the Surface Studio
Cosa ti serve
Lay the Surface face down on a padded surface
Remove the four rubber feet at each corner concealing the Torx screws
Remove the four Torx screws under the rubber feet.
Two screws on the upper corners are longer than two screws on the lower corners.
Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
Lift the black plastic flap attached to the data cable retainer and rotate it away from motherboard.
Pull the data cable out of its socket.
Disconnect the data cable connecting the headphone jack to the SD card slot modular board
Remove three torx screws holding the SD card slot modular board
Remove the SD card slot modular board
Remove a torx screw holding the headphone jack
Remove the headphone jack
Altre 7 persone hanno completato questa guida.
3Commenti sulla guida
I would like to find a new motherboard too… 32gb ram though.
