Salta al contenuto principale
SuperSonic Matrix Mid SC-999 Speaker Replacement
Cosa ti serve
  1. SuperSonic Matrix Mid SC-999 Speaker Replacement, Back Cover: passo 1, immagine 1 di 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Speaker Replacement: passo 2, immagine 1 di 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Speaker Replacement: passo 3, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Speaker Replacement: passo 3, immagine 2 di 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Speaker Replacement, Speaker: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the Speakers
    • Use the tweezers to remove the speakers from their compartments.
  5. SuperSonic Matrix Mid SC-999 Speaker Replacement: passo 5, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Speaker Replacement: passo 5, immagine 2 di 2
    • Desolder the 4 Speaker Wires
    • These wires connect the speakers to the motherboard. They are the thinnest wires.
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
Conclusione
Johncy George
Membro da: 03/26/15
101 Reputazione
1 Guida realizzata
Baylor, Team 6-1, Shaver Spring 2015 Membro di Baylor, Team 6-1, Shaver Spring 2015
BU-SHAVER-S15S6G1
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 322
