Salta al contenuto principale
SuperSonic Matrix Mid SC-999 Motherboard Replacement
Cosa ti serve
  1. SuperSonic Matrix Mid SC-999 Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 2, immagine 1 di 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 3, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 3, immagine 2 di 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Motherboard Replacement, Battery: passo 4, immagine 1 di 3 SuperSonic Matrix Mid SC-999 Motherboard Replacement, Battery: passo 4, immagine 2 di 3 SuperSonic Matrix Mid SC-999 Motherboard Replacement, Battery: passo 4, immagine 3 di 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 5, immagine 1 di 3 SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 5, immagine 2 di 3 SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 5, immagine 3 di 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
  6. SuperSonic Matrix Mid SC-999 Motherboard Replacement, Rear Facing Camera: passo 6, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Motherboard Replacement, Rear Facing Camera: passo 6, immagine 2 di 2
    • Remove the two Phillips #00 screws attaching the housing of the camera to the device.
  7. SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 7, immagine 1 di 1
    • With the screws removed you should easily be able to remove the camera unit.
  8. SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 8, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 8, immagine 2 di 2
    • Follow the camera unit back to the motherboard.
    • Use the spudger tool to remove the camera.
  9. SuperSonic Matrix Mid SC-999 Motherboard Replacement, Speaker: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the Speakers
    • Use the tweezers to remove the speakers from their compartments.
  10. SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 10, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 10, immagine 2 di 2
    • Desolder the 4 Speaker Wires
    • These wires connect the speakers to the motherboard. They are the thinnest wires.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
  11. SuperSonic Matrix Mid SC-999 Motherboard Replacement, Microphone: passo 11, immagine 1 di 1
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
  12. SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 12, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 12, immagine 2 di 2
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
  13. SuperSonic Matrix Mid SC-999 Motherboard Replacement, FM Antenna: passo 13, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Motherboard Replacement, FM Antenna: passo 13, immagine 2 di 2
    • Use a soldering iron to desolder the region circled in red.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
  14. SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 14, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 14, immagine 2 di 2
    • Desolder the FM antenna from the motherboard.
  15. SuperSonic Matrix Mid SC-999 Motherboard Replacement, Motherboard: passo 15, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Motherboard Replacement, Motherboard: passo 15, immagine 2 di 2
    • Remove the large ribbon cable from the socket that attaches it to the motherboard.
    • Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
  16. SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 16, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 16, immagine 2 di 2
    • Remove the small ribbon cable from the socket that attaches it to the motherboard.
    • Flip the dark grey latch to release the ribbon cable from the motherboard.
  17. SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 17, immagine 1 di 3 SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 17, immagine 2 di 3 SuperSonic Matrix Mid SC-999 Motherboard Replacement: passo 17, immagine 3 di 3
    • Remove the four Phillips #00 screws attaching the motherboard to the device.
Conclusione
Dr Shaverz boyz Membro di Dr Shaverz boyz
Community
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 336
